Processors 1.5 and 1.6ghz are sure thing to be modable to 2.0 and 2.13. These two processors almost always pin mod successfully without any voltage adjustments
1.7ghz cpu can pin mod succesfully as well, but there is a good chance with cpus 1.7 and up that they may require more voltage to run properly, thus voltage pin mods might be needed.
Yup that is correct... Remember to check and see if you actually need to do the volt mod... every now and then there is a 1.7 that is 24 hour prime stable without the mod...
Mine failed prime 95 within 10 minuiets so that's why I did the volt mod.
