- Mar 15, 2004
if you dont end up finding distilled water, and you can get you can get your hand on some bottled water, i would suggest aquafina, as it is the most pure of the pure waters, i believe it has gone through 4 or 5 different purification and distilation processes. i just dont know if pepsi products are avalible in irland. good luck with it tho!!
ps if you cant find aquifina make sure to not get any spring water as it has a higher ph level and can cause problems in the metals for the loop
