- Mar 13, 2004
- USA, Vermont
Well water cooling ram has always interrested me an I have always though that there was a abetter way than what i have seen so i came up with my own design to be used with chilled water. With chilled water the top will be copper unless someone knows of a clear low temp plastic as insulation wont be used because I am making a nitrogen sealed box so that you can see the block and all.
There is another block for the back side and the last two screw holes screw them together and the notches in the back ar to go over the locking tabs.
Duke
Duke
