using loose leds
I'm guessing you'll need to use a resistor to get the voltage down for the 2-2.6V called for on those LEDs . This way you can power them using whatever voltage you want as long as the proper resistor is used.
Found this on the web to help calculate what resistor is needed.
http://led.linear1.org/1led.wiz
yep i did it, didnt need one, its a little darker now but at least its RED! looks soo badass ill take a pic later
