- Jul 15, 2005
I am going to mod my case for additional fans, and while I didn't think of this, a friend suggested that I try to squeeze 92mm fans into the back part of the case where there are 80mm fans now.
The case listed in my sig has mounts for 2 fans in the front and two in the back. If I want to put 92's in there, I would have to remove the mounts first, then do whatever was necessary to mount the 92mm's. My question is, can those mounts be removed? They seem to be clipped on the frame of the case, but they also seem like they are on there for life! Unless there is a clip holding them in place that I can't see...
Has anyone ever taken these mounts off before for the purpose of putting in bigger fans?
