- Sep 6, 2003
I like to run to monitors, but I have been had some difficulties in doing it, so let me post what I have found, this is with a 6800go and the laptop in my sig
With the official nvidia drivers you can run 2 monitors if 1 monitor is is your laptop monitor
With official nvidia drivers you cannot set your external monitor to be the primary monitor unless you set your external (nonlaptop) monitor to be the only monitor
With official nvidia drivers if you are running 2 external monitors (1 from the DVI port and 1 from the VGA port) then it will give you the option in the menu to use only the 2 externals but when ever you try that option it just reverts to 1 external and your laptop monitor
With the Dell drivers everything is almost fine an dandy, occasionaly when I restart I have to repostion my monitors in the windows properties menu
With the Dell drivers you Can set you laptop monitor to be a seconday monitor and your external monitor to be a primary monitor
With the Dell drivers you can run 2 monitors, 1 from VGA, 1 from DVI
I have tried this with two versions of the dell drivers, the ones prior to the BF2 fix and the ones released on 9/14/0 and 3 sets of official nvidia drivers, 2 from the 7X.XX era and also with the 81.84s that were recently released, all with modded infs so they work on the 6800Go
As much as I like to run the latest drivers, I am currently running the dell drivers due to difficulties with 2 monitors and the official nvidia drivers w/ modded inf.
I hope these observations are of help to someone
If anyone happens to find a solution to getting 2 monitors to work flawlessly with the lastest drivers please let me know
