- May 31, 2004
What happens when you UNDER volt your CPU?
The Northwood is rated as 1.525 to 1.6 volts operating range. Mine runs fine so far at 1.33 volts. The temps have dropped dramatically due to the voltage drop.
My new p4 830 D is also running at 1.2 volts now but it is rated as 1.25 minimum. Again the temps are way down.
Prime runs fine on both so far.
Do you think it's safe to continue the undervolting? Why is the minimum voltage so much higher than the chip appears able to run at?
