Results 1 to 4 of 4
  1. #1
    Member FTC's Avatar
    10 Year Badge
    Join Date
    Mar 2002
    Barcelona, Spain
    How to fix a laptop noisy FAN
    Hi,
    I want to share in this thread how you can 'clean up' a laptop fan. In this case, it is a Thinkpad T40 fan that had became too noisy after 1 year folding 24x7.
    Well, you start up with the heatsink/fan complex already dismantled from the laptop :
    Now, with a fat screwdriver you can 'force open' the fan metallic casing from the cooper heatpipe piece :
    ... unti it pops out :
    Then, with a thin screwdriver you can dismount the rotor part :
    So you can see the axis hole, to be oiled :
    Attached Images Attached Images
    Asus Z170i PRO GAMING w/intel 6700K@4.7Ghz + Noctua NH-C14S, 2x8GB Corsair Lpx Vengeance DDR4 3200@3466, Samsung SSD 950 PRO NvME 512GB + WD Black 3TB, Asus Nvidia 1060 DUAL.
    Case Sharkoon Zone C10
    Laptop Lenovo T430 w/i53320M + SSD samsung 850 EVO.
    Printer Canon MG6250
  2. #2
    Member FTC's Avatar
    10 Year Badge
    Join Date
    Mar 2002
    Barcelona, Spain
    OK. Second part.
    Now a close up of the bearing hole :
    And oiling it :
    Then clean it all and attach both pieces again :
    And for last, straighten up the finishings and it's done..
  3. #3
    Join Date
    Dec 2004
    Not sure if this fits your scenario, but thinkpad fans have always been running noisy and often dont turn off. So here is the fan control utility for t4x thinkpads.
    Lenovo T60 : T7200, 1GB DDR2-5300, 120GB HD, ATI x1300
    Lenovo Z60t: C-M 340, 768MB DDR2-4200, 40GB HD, GMA 900
    IBM T43: P-M 760, 1GB DDR2-4200, 60GB HD, ATI x300
  4. #4
    Member FTC's Avatar
    10 Year Badge
    Join Date
    Mar 2002
    Barcelona, Spain
    Thanks, in my case both computers (a T0 and a T42) were completely silent since the beginning. Only the T40 fan became noisy at low RPM after a full year at full speed, 24x7... oiling the bearing a bit, as shown, has completely fixed things (already 2 weeks since I did this).
    Regarding the fan control utility, I agree it may be a great thing for this computers, if you have the reported noise problem... one problem though is that I've read it's not compatible with the Notebook hardware control
    utility, which for me is a *must* for this machines...., since it allows undervolltage of the processor, SMART monitoring, power management, battery control, temperature control and over/under clock of the graphic chip in a very convenient package.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
