- Sep 9, 2002
- under the floorboards
After 50+ hours its finnally done
The car: My 2002 Mazda Protege5
Specs:
AMD k6/2 450mhz processor overclocked to 550mhz on an unknown micro atx mobo.
392Mb pc100
40gig Hard drive
m-1 atx 90 watt automotive powersupply + startup/shutdown controller.
T-view 700-ts 7'' touchscreen monitor
The screen setup
Showing the radar detector hardwire. Its a bit ghetto, but I couldnt bring myself to drill the dash.
The computer in the glovebox. Sort of a tight fit
The bezel under construction. Basically I made an aluminum plate and smoothed it with bondo spot putty. Turned out pretty good I think.
Right now its only being used for mp3s + some divx movies- but a GPS, OBDII reader, and dvd player will go in eventually.
More pics to come of it in action + the audio stuff.
Specs:
392Mb pc100
40gig Hard drive
The screen setup
