- Oct 9, 2001
- Dundalk, Ireland
Damn it!
I had finished upgrading my water cooling, and had water pumping round my system for about 5 minutes (no power going to any components) and i noticed water dripping from my CPU block onto my x800xt.
So i turned off the pump and dried up all the water i could see. I then waited about 10 minutes and turned on the machine with power going to all components. Flashing in red letters was "You have not connected the power cable to your video card". But it was connected.
I tried tens of times to boot but the same thing came up all the time.
I even connected a different power supply to my video card and still the same message was coming up. I then found tiny droplets of water on the AGP connector of the card when i took it out. I dried it off, still nothing.
This was about an hour ago, the card should be dry by now, but it still asks for the power cord to be connected. I'm currently using an old Geforce 2 in the AGP slot, so there's no other damage.
Is my card more than likely damaged beyond repair? Or should I leave it a few days before trying again?
Thanks folks.
Steve,
Voodoomelon
Thanks folks.
Steve,
Voodoomelon
