- Dec 13, 2003
- San Jose, Cali
I've been looking around for cases for awhile now, and I've narrowed it down to these two.
http://www.newegg.com/Product/Product.asp?Item=N82E16811119042
http://www.newegg.com/Product/Product.asp?Item=N82E16811133154
I really like that I can put 3 120m fans in the front of the CM stacker, but I don't like that the top and side are both 80mm fans.
If I got the coolermaster, I'd get the 300mm cross flow fan, and if I got the thermaltake, I'd get this
http://www.newegg.com/Product/Product.asp?Item=N82E16811999812
So which one would you guys recommend? I won't be doing WC yet, but will in the future. Right now I just want to have a case with REALLY good airflow.
Has anyone tried to put a 120mm fan on the side of the CM stacker instead of the 80mm? I figured I could cut out a 120mm hole in the top of the case, and just use that one instead of the 80mm.
Any info would really help
