- Feb 14, 2003
- Southeast US
Backstory:
1.8a northwood (18x100) running at 18x175 @ ~3.2 ghz, I think it was at 1.65 volts.
I recently snagged a SL6Z3 2.4c from ebay, and right now it's running 12x266 @ ~3.2 ghz at 1.575 volts, 5:4 fsb:ram (ddr466, I haven't tested ram capability seriously yet, but I was getting artifacts in Stronghold2 with 1:1 and 2.7 volts so I set the divider to 5:4, artifacts went away.)
Basically I've never pushed voltage hard on a processor or ram before, and I want to know what sort of limits I should be working with. I've seen people say they run ddr at 3.2 volts, so later this week I'll probably start some tests with various voltages to the ram (2x512mb corsair ddr466, spd rates it at cas3 at those speeds). Decent DDR isn't terribly expensive now, so if I cook it I'll be unhappy but I can get more.
The 2.4c on the other hand, it's a used part and I really don't want to burn it up. What's crossing a line with this processor? 1.575 right now @ 3.2 ghz leads me to believe I have some headroom here, but how much?
Cooling is an XP120, 4 heatpipe job with a 120mm fan. Thermal-control is enabled in bios but I have it set fairly aggressive, the fan goes 12v @ 44c. Case cooling / airflow is good. (full size tower, several 80mm fans pushing air in and out.)
