- Jul 23, 2004
- Alta Loma Calif.
thanks coolest for taking your time to do this for use all
Rich
Rich
Version 0.98 - 23rd April, 2008
- Fix: Core Temp sometimes crashes when another program tries to access the log file. - Still needs further testing.
- Add: Show load percentage per core.
- Add: Adjustable Tj.Max value via *.INI file.
- Add: Option to start Core Temp with Windows.
- Add: Support new Intel Mobile processors
- Change: Maximum logging interval is now 99999ms instead of 9999ms.
- Change: Log file layout. Shows current temperature, high\low temperature, core load, CPU speed.
I don't follow.Would it work well with 45nm chips? .... I saw that user can change the TJMax .. can't this be done automatically?
