Arch is a great distro and pacman is really nice, there is another distro called frugalware that also uses pacman but uses different repositories then arch, not sure if it is fully or even partially compatible, but it is also a damn fine distro and quite stable from my experience, you might consider giving frugalware a whirl to.
frugalware comes with all sorts of codecs installed and flash and j2sdk installed as well. makes setup very easy. also, windows codecs and flash work in 64 bit which is a PITA to set up, so that was nice to.
