- Jun 15, 2003
- Cedar Rapids, Iowa
I came from AMD and just bought myself a Bad Axe 2, 2GB of Wintec AmpX (the chips look a lot like Micron D9), and a Xeon 3060. I have a phase system that I will be settting this up on as well.
What are some basic steps to go about overclocking?
Should I put the memory/vcore/mch voltages to the max I'm going to want them at and go from there? Also, the DDR2 speeds are confusing the heck out of me, I've read the information here: http://www.peakin.com/xbx2/index.html but if anyone could better explain the different settings that would be great -- timings I do understand but there's so many different frequencies you're dealing with/figuring it's ridiculous.
What's a good starting point for overclocking here? Right now I'm sitting at a very slight 2.7 ghz overclock with stock voltages across the board, 9x300.
I've done a lot of reading but was just wondering if anyone had any experience/words of wisdom for C2D overclocking.
PS - I did read the XS thread and the information I need is in there but I hate how monolithic the thread(s) are @ XS, it takes hours of digging through a thread to find what you're looking for.
Thanks ahead of time,
Derek
Derek
