- Sep 21, 2002
Ok, so after several readings and a lot of discussion, I have one question.
How do you OC in 'relative safety' if you can't keep an eye on the temps vs. Intel's temp specs?
Or, what idle/load temps are successfull OCer's getting with 24/7 operation of an E4300 and how are they getting those temps? Also, how long have you been running that setup?
If we can't find a way to easily read the temp that intel has set for the cpu, lets try to establish a standard that we know is 'safe' for ourselves.
