- Jul 3, 2006
- UK
im using a cooler master hyper tx and the voltage is 1.325V
also just out of curiosity i tried going back to the stock clock speed and my temps still all read the same (in the bios, everest, and TAT) so i think there is something wrong with the temp sensor for my processor
Wow cut down on the voltage there! Most C2Ds can run under the rated voltage when mildly overclocked (my e6300 can run on 1.184v at 3Ghz). Put the voltage down to 1.25v (the default). I take it you're reading the voltage from the BIOs right? That should help ease the temps a bit.
Use Intel TAT (google it) and tell us what your core temps are on that.
Your temperatures could be high due to the thermal paste application and/or the contact the heatsink has with the CPU.
