- Jan 2, 2008
Hey Guys! This is my first post here at OC, and I'm looking for some help. I'm currently working on overclocking my new Pentium e2160 CPU. Right now it's clocked at 2.4ghz with stock cooling. Anyway, here's my problem. I'm aware that the e2160 can reach a maximum temp of 73 degrees celcius, but I'm curious of my own CPU's operating temp.
Right now, it's in the C0 state (don't know what that is, can someone chime in). Both cores, according to Core Temp, are at 46-degrees celcius. This is in a computer room with the heat set up to 70 degrees Fahrenheit. If it helps to describe, my computer room is the second hottest room in the house, as it is directly above the boiler room. It's a pretty small room with two computers running in it.
Anyway, is 46 degrees ok? My computer froze not too long after I OC'ed it (surprisingly), and I thought it might have been the operating temp, so I opened the window and turned on a desk fan and let the 16-degree frigid air come into the room. My e2160 dropped to 42-degrees Celsius at that point.
So, is 46 celcius alright in a warm room, for a processor on stock cooling inside a case with three other fans? Also, what is a optimal temperature range that I should always be in for the health of my e2160? Any help would be great. Thanks!
