- Jan 18, 2001
- Athens - Greece
Well, the problem is about the settings available into the Display Properties\Power Option Properties, where you can set the time that will turn off the Monitor. The strange thing is that isn't available, into the Advanced Settings too, so, every time i leave the Pc for more than 10-15min the system turn the monitor in sleep Mode and doesn't wake up at all!!! and I need to restart the System!!!
Can you suggest me the proper voice into the registry to set this prob? I suppose that is a prob releated to the Vid Drivers.
Thanks in advance for your support
