- Mar 13, 2006
Ok per a few requests I am going to start a thread detailing my ideas/plans/wants/needs for the Condo I am buying. This thread is NOT going to be a one off type thread. I am going to update it as I find what I am looking for or as I get bits done AKA LONG TERM THREAD!
I am "buying" an 840sf. condo. Not at all large, but a good start to my eventual plans of owning a castle or an island. It is 4 rooms (well 5 but the dining room and living room are combined) LR, Kitchen, BR, Bath.
I want to make it a smart home in a sense.
Things I want to do:
-Automate Blinds:
-Automate Blinds:
- Current foreseeable issues I have are, well I dont have any blinds up in the new condo and the current condo I live in has vertical blinds which require them to be turned 50% from L to R prior to being drawn open (will not open fully otherwise as they will bind up). I will need to find an assembly that can rotate 50% open and reverse the same procedure.
- Very easy to accomplish, only takes a few hours to complete, involving a few tools
- Hole saw
- Screwdriver (phillips and Slot)
- pliers to attach mounting brackets to drywall
- fishtape for longer runs
- flashlight
- Punch down tool for crimping Cat5e connections
- RJ45 jacks
- wall plates for assorted connections (I will be using keyhold plates as they are standard and have multiple snap in connections for the various ideas I have)
- will need to find a Managed switch to replace existing unmanaged for security control
- will also possibly need to convert a machine over to a Server OS and join all machines to the Domain for access control to the network.
- Slightly harder then Networking as certain plans may require more involved methods. Much shorter runs are required due to signal degradation, also each splitter will introduce some signal degradation as well.
- Keystone plates again can be used here as they have RCA snap in plugs as well
- Same tools as above
- Is easily done Via X10 and similar. I may look at a single controller for everything which would be much more expensive. This will be hopefully incorporated with automating fishtank controls and may be done via X10 or similar until a better option is found and installed.
- easily done via networked condo and soundcard connections to HT. Other smaller options are available.
- see lighting control
- there are programs available to stream to a webpage, even YIM could be used. Only foreseeable issue will be the ISP limitations.
