Intel to drop overclocking for mainstream Nehalems
intel has done many things in the past that were to be the end of overclocking, such as locking multipliers on the PII chips. And this has hardly stopped people overclocking.
I think, as at least one other person pointed out, that this means there will only be XE chips on s1366 (which would be expected anyways, being XE chips). XE chips are the only was that officially support overclocking anyways.
Random thought: Let's consider this as if it were verifiable information for a minute, and assume that Intel doesn't care about the tiny percentage of people who overclock (and spend loads of money on CPUs anyway.) Maybe there's a reason for them to restrict it? For example, what if they are looking at 22nm (or whatever the next shrink is) samples and figuring out that the silicon can't handle any more voltage than they are planning to put through it at stock speeds? In that case it would make sense to start weening us off in advance to lessen the shock later. There would be no market risk (AMD) because they are subject to the same physical limitations as long as they don't have some ridiculously advanced technology.
Probably a nutty thought, but mostly logical.
Well that is not a good business model, playing the concerned parent.
In actuality if the 22nm as you say, gets overvolted and fried then overclockers need to buy more cpus. Hence more business :)
(Although much like nVidia proved back in the day, word of mouth from an enthusiast is worth its weight in gold ...)
aside from producing a few chips that have an unlocked multiplier, Intel has never supported overclocking. This "moving the northbridge onto the chip" is just Intel just following AMD in their Athlon64 design. The ability to overclock is designated by the motherboard (bios or jumpers) and I don't see that changing as long as Intel still produces x86 chips and allows 3rd parties to produce motherboards.
Even PPC macs (desktops and laptops) can be overclocked by modding the mobo, and Apple doesn't support overclocking.
even my linksys router running dd-wrt can be overclocked.
Don't worry. Overclocking isn't dead and it isn't dying. Netcraft confirms it.
