- Dec 7, 2003
- Thread Starter
- #81
And then it dawned on me. I've got a completely disassemble-able frame made from tubular aluminum. Why not route the wires right through the frame?
The first step was to remove the necessary frame bars and punch some holes into them:
The light blue arrows point to the holes I punched out. The red arrows indicate where the bar originally came from. As you can see, this would be nearly impossible without being able to disassemble the frame.
The holes were made with: good ol' nibbler tool, then sanded to a dull edge:
