Just started Orthos to test stability @4GHZ on my e8400 C0. Looking at different temp monitoring software, Real Temp and Core Temp show the same values, and SpeedFan seems to show 5C higher so I put an offset of -5 on each core to make it display the same.
Except, the CPU temp shows 10C lower than the Cores' temps... isn't this abnormal? I read somewhere that the Core temps shouldn't be more than 1-2C higher than the CPU temp...?
