For some reason if I have Storage set to detect as "AHCI" to use SATA, it makes games unplayable... like I would load a game and within a few minutes it freezes, then artifacts, or sometimes if loading a new scene/voiceover it errors out to desktop. It seems like the data gets corrupted when it's loading something. When I turn off SATA by making it detect as "IDE" then the issue is gone.
Is there some other settings in the BIOS I need to change in order for SATA to work properly? The games hard drive is a 750GB SATAII Seagate and CPU is e8400 mildly OC'd to 3.6 @ 1.225v. Do I need to give more voltage to the SB or something? I've never touched that setting because I'm not sure what the default SB voltage is, how much to increase it, nor ever heard of anyone needing to up the SB for OC'ing (only the NB). But I'm guessing the corruption is caused by an unstable SB since that's what controls SATA.
So far I haven't been seriously able to OC my CPU, trying to deal with a million issues at once before going for 4ghz+.
