Vaseline sort of works, but I don't think it's the best if the TECs hotside heats up too much.Just a quick Side Question:
Is Vaseline pretty much the same thing as Die Electric grease or is there a benefit to using the latter over it.
Please note, you are only suppose to use it to seal the TECs sides if you have an open TEC device. If it is already sealed then you are fine.
