Filesystem:
Undecided between XFS/JFS/others. I'm going to use VMWare to run Debian to see how much I can get used to it and see how good it really is. I'm open to suggestions, but I'd rather not use Solaris or Redhat. I'd consider CentOS again.
*Backup folders WITHOUT paid software (aka: Acronis). I have two legit copies of Acronis, but I don't like the proprietary format that it uses and I've hit some snages when trying to restore files. I got a really good deal on the software and it does an amazing job, but I need more than 2 copies and I have no money; so buying more is out of the quesiton. I'd rather just have a gzip'd file or individual folders as backups. I believe that rsync can help with this, I just need to find a suitable Windows based client.
*Hostnames. This sounds silly, but even when I give the server a name like "thideras-server" and the host OS is linux, I can never use "thideras-server" to access shares or services, I always need to use the IP address. This isn't a huge issue and more of an annoyance, but something I'd like to fix. This is mainly so that users who don't know anything about my server, can still use it.
*Monitoring of system resources. I didn't have a really good way (graphs, etc) to monitor the server. CPU usages, memory usage, hdd usage/activity, network usage and many more; the more detailed, the better. A web interface (internal/external) would be preferred, even if just to "see" the usage.
*Understand accessing shares better. I had a really hard time with users/usergroups and shares when I used CentOS/Solaris as the OS. I'm not sure what confused me, but if anyone knows a good explanation, I'm listening.
*Understand SAMBA better. I'm not sure what I was doing wrong, but I was getting terrible throughput for gigabit networks (15-20mb/sec) and massive CPU usage (two cores at 100%) when transferring files. The two processes were SAMBA, that was clear via 'top', but I don't understand why. It seems ridiculous that it would need that much CPU, so I'll chalk that up to being a linux server nub. I've found a few guides that "explain" what each flag does in the setup file, but they fail to show examples or go into great detail. I'm left guessing or trying to figure out what everything does.
*Find a FTP server. I'm spoiled. I've been using FileZilla in Windows and I absolutely love how easy it is to setup.
I've heard there are issues with it not running on a Solaris based OS. I'd consider FreeBSD, I can create another VM later and try it out.I am assuming you have given ZFS a shot? FreeBSD 8.0 now has production support for ZFS and I am a FreeBSD fan. Another option is to use Debian as your base OS and run the Xen hypervisor.
It is funny you mention this one, that is the first thing I found. Do you have experience with it?I believe DeltaCopy is what you are looking for.
I can tell you haven't been following the threadWhat device are you using for routing/DHCP/DNS/NAT? Most home routers (Access Points) use a program called dnsmasq. You need to look into allowing expand-hosts, which will resolve "thideras-server" to the IP.
I have Cacti up and running, which using RRDTool. I broke it, so I'm trying to figure out what happened there.For linux look into: ntop, bandwidthd, collectd, and rrdtool.
I'll give it a look over, thanks.I have only setup samba once but this looks like a good guide if you haven't seen it: https://help.ubuntu.com/community/SettingUpSamba
I actually did not know that it transmits everything in plain text. I've bookmarked that and will check it out.I honestly would suggest using SSH over FTP but if you still need FTP, I would look here: http://www.howtoforge.com/proftpd-tls-debian-etch
*sighs*, I really need to stop being bored. I'm waiting for the drive to be created so the virtual machine can start up, then to XFS testing!(12:46:07 PM) thideras: stupid selinux got in the way
(12:46:24 PM) VisualBits.net: ROFL
(12:47:47 PM) thideras: setenforce is my friend
(12:48:00 PM) thideras: sounds german
(12:48:04 PM) thideras: he is my german body guard
(12:48:25 PM) thideras: SETENFORCE, PUT IT BACK IN THE BOX
(12:51:01 PM) thideras: setenforce says "Werde ich alles tun Sie bitte" (I'll do anything you ask)
(12:51:05 PM) thideras: and he says hi
(12:53:06 PM) VisualBits.net: LOL
(12:53:12 PM) VisualBits.net: SAY HELLO TO MY LITTLE FRIEND
FreeBSD confused me at first until I realized it didn't install BASH and I had to run it manually; didn't really care for that OS.
chsh -s /usr/local/bin/bash
I had BASH installed, but I didn't know how to load it by default, good information.FreeBSD comes with the Bourne shell by default, you just need to install BASH either by binary packages or source packages, then run:
However I would not recommend changing root's default shell to bash.Code:chsh -s /usr/local/bin/bash
The only thing that isn't working right now is printers, but I'm sure it is a setup issue as I have never done it before.
I also decided on the EXT4 filesystem which surprised me. Not that the selection surprised me, but how fast it ran. I was getting 50mb/sec transfer to the virtual machine, which was storing its file on a Windows NTFS partition running on top of a Perc 5. I found that extremely impressive and hope to get better performance when it is the host OS.
Are you using CUPS?
So this is useing CentOS as the host OS and using VMware Server?
Correct. The printer is a Brother HL-2140. I have the PPD file for it, but I don't know where to put it. The guides don't really "guide" you.Are you using CUPS?
The host operating system is Windows Server 2003. I have virtual machines under that (CentOS, etc) until I am confident that I want to go with a particular flavor of linux. I'm going to try out Fedora shortly since a friend requested it.I had to read it a few times to understand it. The way I understand it is, he's using FreeBSD currently, but using CentOS guest in a VM. Centos was apparently copying a file from an NTFS share to itself at about 50mbps.
I don't have a rack yet.Can you post a picture of the rackmount that all the equipment is in?
I want one too D:I myself want to see the rack more than anything, thid. Better hurry up and get 'em racked.
I want one too D:
No one around here sells 'em.
