Shortly after I woke up today, I was greeted with a "CRACK" loud enough that I thought it was my laser printer falling off the rack. A long UPS beep quickly followed. When I got over to the rack, I smelled the most rancid electronics burning smell ever. I frantically tried to locate what equipment exploded.
Hard drives were ok. Top R710 was ok. Bottom R710 was ok. Switch was lit up. I couldn't find the culprit and the smell wasn't going away. After some more quick investigating, I saw the lights on the pfSense router were off. The Optiplex 780's power supply literally exploded. I tore it apart to check what failed and I can't find any burn marks or exploded chips. There is a piece rattling under the board, though.
I need a router since I work from home, so I tried to find replacement parts locally, which I expected to be a bust. There is a nearby shop that I stopped by and they didn't have it, but could order it (yeah, thanks...). They had a couple small systems, but wanted $250 for a tower-only system older than my Core2 setup. Yeah. Right.
On the way home, I was contemplating using my spare router, which seems obvious to use. However, the capacitors in it are bulging and I have replacements for them. So, do I risk killing my only spare system to fix capacitors or run on the broken ones hoping they work? Since I work tomorrow, I decided that it would be a bad idea to replace them. I got the hard drive migrated over to the new system, configured the interfaces, and put it on the network. Works great. However, I hear the hard drive struggling to stay running, because of course why not, right?
With the fragility of my current router setup in mind, I decided now is the time to get a reliable system. Problem is, building my own is substantially more expensive than I thought. The cheapest case I could find that had (easy to locate) dual power supplies was $200 just for the case. I'd still have to furnish it with a motherboard, CPU, RAM, drives, possibly a RAID controller, etc. That adds up incredibly quick.
Instead, I messaged Visbits, who has helped me out a ton with servers and asked for a suggestion. He recommended the Poweredge R410. It is the same socket as my R710, will have similar build quality, and could take an iDrac! Perfect.
I should have one shortly. Commence Router Overkill.
