- Dec 18, 2000
- The battle born State
I know, I am a senior, but for many reasons I have not been around this board much in the last 5 or so years. Well then I read about the e5200 and it's excellent overclocking ability, and I guess the bug bit me again...
So I ordered the E5200 together with a Gigabyte EP43 (ICH10 south bridge) and 4GB of corsair PC8500C memory.
So far I am stable at 300MHz x 12.5=3.75GHz and memory at 1200MHz (300x4) with slightly relaxed timings (777-18 instead of 555-15) and at 2.0V. Processor has original heatsink and no voltage increase (runs at about 1.25V under load).
I am quite happy, as this is almost an out of the box result, but of course I want more...
A couple of questions - sorry if I am a little rusty or
- the e5200 does not seem to be unlocked - is that correct?
- in cpu-z it shows the multiplier drop to 6 when idle and jump to 12.5 when busy - I guess that is power/performance throtteling?
- the memory appears to be good to 1260 or so with the current timings, the cpu however does not like fsb over 310 or so - I had it running briefly at 318 (=3.97GHz) but that's not stable. I bumped up cpu core voltage to 1.35 briefly, but no real change.
- I am almost under the impression that the board does not want to go over 310 or so - not sure, but there are other voltage adjustments on the board, which I have not really touched yet - they seem not to be documented very well though.
If anyone with a similar set-up could weigh in here I would appreciate it
Thank you
Yomama
Thank you
Yomama
