- Sep 4, 2006
Hey...fwiw...I just now noticed that charlie mentioned Vista in his list in post #6....sorry charlie...I didn't see that.
Also...I also strongly suggest to get as good a power supply as your budget will allow...one that has a solid reputation. No...you don't need a 600w or even a 500w...a 400w would probably be more than enough...unless you put in a high power requirement video card...which I assume that you will not do.
If you think about it, the power supply is the heart of the whole system. Everything has to have power...good, steady power.
Take a look at this Thermaltake at newegg...a real good psu:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817153023.
There are other good psu's....I just thought that this one was a real good deal....great reputation...good power...good reliable specs.
