Quick TRUE 120 question
I believe that AM2, AM2+, and AM3 are all identical from a cooling point of view.
They are basically the same from a hardware point of view too! But you are indeed correct, they are all interchangeable.
if i'm not mistaken, the true's don't come w/ am2/3 backside mobo brackets.
you have to get them separately.
the top mounting though if the screws fit on the existing mobo mounting
should work fine.
