- Mar 27, 2005
- Fresno, CA
I'm setting up a new system with a EVGA E760 Classified and EK-FB_EVGA_X58_Classified motherboard waterblock.
I'm wondering what is the best way to connect the motherboard and CPU blocks? I know that if I just use a typical hose connect, it’s going to kink. You can see what I mean in this pic. Notice how close the top hole of the motherboard block is to the CPU . . .
So I’m thinking about using two of these 90 Degree Rotary Fittings.
I figure I could put one on the CPU block, and one on the motherboard block. Then I can just run a hose directly between them. Would that work?
