- Aug 18, 2008
Ok all I really want to slap a tec on something and since I don’t have a lan rig yet I think I’m going to (when I start building it) slap a tec on that. I just got a 400 watt tec from ebay (usa seller if that makes a diff) and after testing I’m kind of disappointed. after 5 min the tec's surface only got down to -3.4F (using laser temp gun) and for some reason I think it should be lower
What I used to test
psu: 700 watt (mod to just run tec)
rad: car heater core
fan: 2 120mm 88 cfm fans
tubing: 1/2
pump: i forget what kind of pump it is
block: swiftech gt water block
TIM: AS5
the rad never got any hotter then room temp (around 68F)
should the temps on the tec face be lower?
after 5 min
What I used to test
tubing: 1/2
TIM: AS5
after 5 min
