- Mar 13, 2004
- USA, Vermont
Well for the last few days overclocks that where once stable (2.8 280x10 1.5 volts) started to become unstable i was doing alot of bios changing at the time so i thought it might just b the bios, so i flashed back to the 623-1's that i had the best luck with and used the computer for a few hrs at 275x10 2.75 at 1.45, changed a few ram settings (i think it was tras from 6 to 8, and DDS from 7 to 8) did a memtest run and everything was fine loaded windows and i got a bluescreen once i got to the desktop, figured ok something is off with the ram timings now (so i set them back to an older stable set of timings that i had, and lowerd my cpu multi) got into windows again and ran OCCT, i hit start and looked at the temps and core 2 was at 65 deg c (this was at 2.0 at 1.3v mind u) and blue screen again right after i saw that, now i cant even load windows, that 65degs on core 2 is about 15 deg higher then i have EVER seen the temp it normally ran about 50 deg MAX at 2.8 and 1.5 volts (nothing was changed cooling wise and the comp hasnt moved in weeks so the heat sink hasn't been jarred)
Pretty much i would love some input as to what u think happened, anything and everything will b greatly appreciated
Duke
PS. this is now the PERFECT excuse for my GF so i can finally order my new parts, (she caught me on newegg.com with a full shopping cart lol, damn her timing was about 3 clicks away from ordering lul) but at the same time i would love it if i could save this system as a back-up
Duke
