- Jan 29, 2009
theres an mcp355 @ chilled pc and a swifty triple rad for 45
http://www.chilledpc.co.uk/shop/product_info.php?products_id=181
It should be OD outer diameter for barb fittings (you need to use clamps and same ID inner diameter tubing).What is barb size?
Georanma - unless your govs bought it and had it shipped over in numberd pieces rest of the uk wouldnt notice mayhap #Chuckles# excuse me
in the case of the suggested pump its G3/8 so if that was your choice then your best to stick with that size throughout.
Are you so sure ? HK3 is one of best and in stockEvery CPU Block that is amd compatible is out of stock! lol
You should be able get XSPC Laing DDC acrylic top with 1/4" tread and can fit any diameter fittings that use 1/4" with it.The Swiftech MCP355 Is available in 1/2" and 3/8"?
EDIT : which is the better for me?
This reservoir is better:So how about this so far...
http://www.aquatuning.co.uk/product...939-940-AM2-Rev-3-NEU-RM--3-point-mount-.html
http://www.chilledpc.co.uk/shop/product_info.php?cPath=41_110&products_id=557
http://www.chilledpc.co.uk/shop/product_info.php?cPath=42&products_id=433
EDIT : + http://www.chilledpc.co.uk/shop/prod...roducts_id=425
what sort of fittings will be needed?
http://www.chilledpc.co.uk/shop/prod...roducts_id=515
