I'm rockin' the Big Water 735 right now with an extra 2x120mm radioator, and with a different waterblock. I did use the block though, and its not bad. Its not the best, but its pretty decent. All in all its a pretty nice setup, and its worked really well for me so far! Here's the link. Good luck man!
Thanks but i have already put together my own setup all is running super
Done a little overclock dont really have time through the week so i am working at it bit by bit, so far core speed is at 3600Mhz not touched the multiplier still at stock x15 going to try and use reference clock as it gives an overall overclock stock was 3000Mhz Voltage is at 1.3750v Temps under load (Prime 2hours) no higher than 41deg
Going to clock it a bit more tonight might hit the 4000Mhz tonight see how it goes
