Hi,
I upgraded the CPU in my son's Gateway MX8738 from a T2080 (533 FSB, 1.73Ghz) to a T5200 (also 533 FSB). My goal was to allow him to upgrade to a 64-bit OS.
When I bought the T5200, I was only concerned about matching the FSB. I didn't realize the T5200 is clocked at 1.60Ghz. He's noticed a performance drop.
My questions:
1. Could I replace the T5200 with a T5600 (SL9SG (B2), 1.83 GHz, 667 MHz FSB), or even a T7200 (SL9SF (B2), 2.00 GHz, 667 MHz FSB), T7400 (SL9SE (B2), 2.17Ghz, 667 MHz FSB), or T7600 (SL9SD (B2), 2.33Ghz, 667 MHz FSB). All the above parts are Socket M.
The question is whether the Intel CPU would adjust to the lower FSB-- Intel's site is a bit unclear on this point. I know that with the lower-end Intel943GML/GMA950, it's locked to a 533 MHz FSB).
2. If the above is not possible, then could we overclock the T5200 that I just installed? The installed memory speed is 667 MHz DDR2.
3. Lastly, by moving from a Dual Core to a Core 2 Duo, I know he now has support for the 64-bit extensions. Could we increase the installed RAM from 2GB to 4GB? (There are two slots). I guess I'm asking if the issue is a mobo one, or RAM address-ability (x64 vs. x32) issue.
Thanks, in advance for any help!
BTW, his laptop specs are: Dual Core T2080 | 1.73 GHz | 533 MHz FSB | 943GML | GMA950 | 2 GB 667 MHz DDR2 RAM |
My questions:
