- Feb 22, 2009
I am running my Push/Pull Panaflos. 2600 RPM versions. On the Fan Controller they only hit 2400 RPMs no big deal.
Here is the problem. When I turn the speed all the way up, the rear Coolermaster 140 mm fan picks up air resistance and appears to slow down.
Judging by the Fan speed program though, the speed remains constant.
The rear fan is only a 700 RPM fan and I am running the 38mm Panaflos in push and pull putting the "pull" fan 2-3 inches away from the rear case fan. Would I be better off removing the rear fan all together? Could it be causing an obstruction? Do I need to put in a faster 140mm Case fan? If so, which. From all the 140s i see Noctua has the fastest one at 1300 RPMs, but I don't have any clue.
