- Dec 19, 2005
- New York
Guys, I am a performance junkie but also prefer against having noisy 70 DB lawnmower fans on my HS. Over the last 1 and 1/2 year or so, I have built about 7 different Core i7-920 C0 and D0 rigs for myself, family, friends, and customers. I have always used the TRUE Original, up until the current build which included the Venomous X. Again, I always use Dual Noctua NF-S12B FLX for all of my builds for the longest time now. I am very happy with noise to performance ratio of these 19.99 Noctua fans: http://www.jab-tech.com/Noctua-NF-S12B-FLX-120mm-Premium-Fan-pr-4440.html Specs of Current Fan: 59.4 CFM @ 18 decibels
However, I have been building rigs but havent really browsed OCForums for a while and am unfamiliar with the current top of the line noise to performance push/pull fans that you guys recommend. I want more performance, but I also want quiet similar to the current Noctuas I am using. I am willing to go up to 25 decibels maximum, but need more cooling capacity for my i7 overclocks.
-D
PS- In case you are wondering, my best D0 build is using a TRUE rev. c with dual noctuas. Cpu made it to 4.59 GHz, HT enabled, prime/linx stable for 20+ hours so I know my current setup works. I just want to see if you guys have something thats even better?
-D
