As a totally complete content-free post, my last rev1 fan controller is up for sale in the classifieds: http://www.overclockers.com/forums/showthread.php?t=682803
apparently I'm not allowed to view the classifieds
Bobnova said:I'm contemplating designs for a non-PWM fan controller
On an entirely different and somewhat more on-topic note, I'm contemplating designs for a non-PWM fan controller via the same chip I used for the PWM version.
So I just finished reading this thread, I think it's a great read. As I went through, I had a similar thought as Bobnova did
There's already a ton of good stuff going into the PWM control, so what I was thinking was why change it? My thought is to tack on a little bit at the end of the circuit so that you can hook up either a 4 pin fan as is or a 3 pin fan with the extra bit. The circuit I found looks like this (This might have been mentioned elsewhere in this thread):
Lifted from this thread
So essentially take the PWM out from Bing's PWM circuit and feed it into this circuit. Now your 3 pin fan is as good as a 4 pin fan. (At least in theory)
I don't remember all of my circuit theory, but essentially uses the MOSFET as a solid state switch to power on and off the 12V rail to the fan and have it spin as per the duty cycle.
Some high end fans specifically don't want the input voltage PWM'd, not entirely certain why though.
Pulse-width modulation of dc operating voltage to modify fan speed is not recommended. Transients generated by that approach can irreversibly damage motor commutation and control electronics and dramatically shorten the life of a fan.
T=K, I don't think it will work as expected, honestly I'm not quite follow how it will work ?
Also why are you using a comparator LM311 instead of common op-amp ? And the non-inverting input is not connected, even its an op-amp will not work that way.
Fyi, the LM317 regulator will not provide full 12 volt at max speed if needed, that regulator will drop quite some voltage, worry the max volt for the fan probably about 9-10 or even 8 volt.
