10lbs! thats enough for a session.
You know, someone told me to through dice in the fire... and all it did was put it out. I figured it would explode but NO, nothing. I was very disappointed.
I had an issue with my DICE. I put it in the container, but it didn't get cold at all. Stayed room temp. Help?
http://i55.photobucket.com/albums/g121/thideras/Benches/ea84464c.jpg
You're a bit low on acetoneI had an issue with my DICE. I put it in the container, but it didn't get cold at all. Stayed room temp. Help?
Should I buy my DICE elsewhere? Was this batch bad? Should I roll again?? I'm very confused, any input is greatly appreciated.
I'll try that, but the usual reports of "not being able to hold the DICE for a long time" due to them being cold is not working, in this case. I'm very confused how my DICE could be defective.You're a bit low on acetone
OH SNAP, they look sick. I'll look at fixing them and getting replacements if needed! Can't believe I missed that!Oh you're right...I just took a closer look at the picture, your dice have spots.
You should have that looked at ASAP!
