- Nov 12, 2002
- Rootstown, OH
That's not the number we are looking for, may need to look elsewhere on the board.
What socket type? (775?)
What number are you looking for? Thanks for all the help by the way.That's not the number we are looking for, may need to look elsewhere on the board.
Short the pins and that will disable this feature:
Sorry, I think you are sol unless something above was done incorrectly.
Did you remove that jumper and try and see if it will power up. also do you have a PS/2 keyboard
Sounds like you have a bad hard drive, can you do a hard drive test from a CD or floppy.
