- Jan 18, 2010
- Calgary, Alberta, CANADA!
It will post and everything starts to load and it says "no hard drive detected". Any ideas? If more information is needed just ask. Z
Is a hard drive connected? Sata right?
I didn't do anything. I bought this rig off a friend of a friend just for casual use. It worked perfectly fine. I switched cases and it still worked fine. Then for awhile I couldn't get the graphics card to turn on. then that magically fixed itself and I got the "no hard drive detcted" or whatever message. Now it says "chassis intruded". I don't know what mobo this is, but its a asus board. I have no idea how to reset the bios.Reset bios. What did you do previously to the problem occurring? Update bios maybe?
Run the CPUZ to see all those detail and post again. I mean if you have a spare HDD just plug in and fresh install Windows see is it work?
Might just be a faulty harddrive, try plugging in another one to see if you are getting that error message.
The drive is fine. During start up it detects the drive and says it's status is ok.
By any chance, is this machine a Dell?
Are you using a usb keyboard.
What ASUS board do you have.
Sometimes the bios does not recognize a USB keyboard and you need to use a PS/2 keyboard to get into bios.
CMOS battery and removing it for several minutes
