- Jul 8, 2010
- San Luis Obispo, CA
I couldn't decide whether I was nuts or if my pc was just screwin with me. I read over my install notes (I take notes to remind myself what I did after a few hundred thousand installs it all blurs together) I think it is a MOBO/BIOS issue.
here's what happened:
I built out the system, tossed in my win7 64bit ultimate dvd.
I installed my os to my 32gb SSD startup drive.
I installed all my drivers and support utilites, IE: CPU Z and other tools. The system showed stability after roughly 30 reboots and then 10 minutes of Prime95.
I downloaded the most recent BIOS update and uploaded it to my usb key.
I used the EZ Flash 2 utility and updated the bios.
I rebooted to a (insert boot device and press any key) screen.
I checked the BIOS since the update reset the defaults.
No matter what defaults were set it refused to boot to the drive.
I had to re-install the OS from scratch again. While it's not THAT big of a deal it does make me worry, am I going to be re-installing for every BIOS update? If so Anyone know a decent usb install utility for Win7 64bit? lol
