SOLVED Where to get metal mesh filter for case?
soulwatch5
Burbank, CA
My rig is set up in a haf 922 with the side panel set up with a 200mm fan. The problem with the Haf 922 is that the side panel doesn't have any real filter to stop dust from entering and I was looking to figure out a way to put some type of wire mesh on to help. I rather set something up where i can easily wipe down a filter every now and then, that would post pone when i had to clean out my case to every 4,5 or 6 months, instead of having to clean it out every month.
Any ideas on what i can do?
