Function FTPUpload(sSite, sUsername, sPassword, sLocalFile, sRemotePath)
'This script is provided under the Creative Commons license located
'at http://creativecommons.org/licenses/by-nc/2.5/ . It may not
'be used for commercial purposes with out the expressed written consent
'of NateRice.com
Const OpenAsDefault = -2
Const FailIfNotExist = 0
Const ForReading = 1
Const ForWriting = 2
Set oFTPScriptFSO = CreateObject("Scripting.FileSystemObject")
Set oFTPScriptShell = CreateObject("WScript.Shell")
sRemotePath = Trim(sRemotePath)
sLocalFile = Trim(sLocalFile)
'----------Path Checks---------
'Here we willcheck the path, if it contains
'spaces then we need to add quotes to ensure
'it parses correctly.
If InStr(sRemotePath, " ") > 0 Then
If Left(sRemotePath, 1) <> """" And Right(sRemotePath, 1) <> """" Then
sRemotePath = """" & sRemotePath & """"
End If
End If
If InStr(sLocalFile, " ") > 0 Then
If Left(sLocalFile, 1) <> """" And Right(sLocalFile, 1) <> """" Then
sLocalFile = """" & sLocalFile & """"
End If
End If
'Check to ensure that a remote path was
'passed. If it's blank then pass a "\"
If Len(sRemotePath) = 0 Then
'Please note that no premptive checking of the
'remote path is done. If it does not exist for some
'reason. Unexpected results may occur.
sRemotePath = "\"
End If
'Check the local path and file to ensure
'that either the a file that exists was
'passed or a wildcard was passed.
If InStr(sLocalFile, "*") Then
If InStr(sLocalFile, " ") Then
FTPUpload = "Error: Wildcard uploads do not work if the path contains a " & _
"space." & vbCRLF
FTPUpload = FTPUpload & "This is a limitation of the Microsoft FTP client."
Exit Function
End If
ElseIf Len(sLocalFile) = 0 Or Not oFTPScriptFSO.FileExists(sLocalFile) Then
'nothing to upload
FTPUpload = "Error: File Not Found."
Exit Function
End If
'--------END Path Checks---------
'build input file for ftp command
sFTPScript = sFTPScript & "USER " & sUsername & vbCRLF
sFTPScript = sFTPScript & sPassword & vbCRLF
sFTPScript = sFTPScript & "cd " & sRemotePath & vbCRLF
sFTPScript = sFTPScript & "binary" & vbCRLF
sFTPScript = sFTPScript & "prompt n" & vbCRLF
sFTPScript = sFTPScript & "put " & sLocalFile & vbCRLF
sFTPScript = sFTPScript & "quit" & vbCRLF & "quit" & vbCRLF & "quit" & vbCRLF
sFTPTemp = oFTPScriptShell.ExpandEnvironmentStrings("%TEMP%")
sFTPTempFile = sFTPTemp & "\" & oFTPScriptFSO.GetTempName
sFTPResults = sFTPTemp & "\" & oFTPScriptFSO.GetTempName
'Write the input file for the ftp command
'to a temporary file.
Set fFTPScript = oFTPScriptFSO.CreateTextFile(sFTPTempFile, True)
fFTPScript.WriteLine(sFTPScript)
fFTPScript.Close
Set fFTPScript = Nothing
oFTPScriptShell.Run "%comspec% /c FTP -n -s:" & sFTPTempFile & " " & sSite & _
" > " & sFTPResults, 0, TRUE
Wscript.Sleep 1000
'Check results of transfer.
Set fFTPResults = oFTPScriptFSO.OpenTextFile(sFTPResults, ForReading, _
FailIfNotExist, OpenAsDefault)
sResults = fFTPResults.ReadAll
fFTPResults.Close
oFTPScriptFSO.DeleteFile(sFTPTempFile)
oFTPScriptFSO.DeleteFile (sFTPResults)
If InStr(sResults, "226 Transfer complete.") > 0 Then
FTPUpload = True
ElseIf InStr(sResults, "File not found") > 0 Then
FTPUpload = "Error: File Not Found"
ElseIf InStr(sResults, "cannot log in.") > 0 Then
FTPUpload = "Error: Login Failed."
Else
FTPUpload = "Error: Unknown."
End If
Set oFTPScriptFSO = Nothing
Set oFTPScriptShell = Nothing
End Function
