FEATURED The Water-Cooled System picture thread v2.0
Very nice build you got there Cert. Really love the bends on the tubing.
If you can, please make a signature with your specs. I can't tell if that's an AX1200i or a AX1500i PSU.
Btw, :welcome: to OCFs! :salute:
Obsidian 900D, X99 Asus WS-E, 5930k (oc 4.4), 32gb ram, 2x 1tb ssd evo 850, Corsair AX 1500i, 3x OG titans sli.
heres what it looks like with the side panel off.
will probably get around to getting a picture of it with the side panels back on later.
edit.
lets see how long until someone points out what i did wrong on this!
You have the PSU upside down and used colored fluid? :D
i meant to do both those things! i want my psu to grab cool outside air.
i donno why EVGA put their sticker on upside down, the corsair RM850 in my other rig the sticker sure looks the right way up!
there is something else that isnt done right!
i donno how much of a difference it makes though
and its not done processing yet, but i'll still try to embed this now, hopefully it will actually work.
well, that didnt work, how's a guy supposed to embed a video from youtube over here? the youtube embed code didnt work...
You have a 4th HDD on a cage that only mounts 3. I would guess the 4th is just sitting there loose.
But you also way over bought with your PSU. :D
My other guess is you have 120.5 of rad for a CPU only loop which I'm guessing you have plans of adding the GPU in the mix down the road.
I'm guessing that really nasty bend from the VRM block to the CPU, looks like it's so tight it would cut flow rate down a lot.
CPU block is plumbed in backwards.
And only way overbought on the PSU because I got a wicked deal on it from OKWolf.
And yeah, loop has so much rad because eventually it will have a GPU to cool. Hoping to get a 290x for a good sometime in the future.
And while the 4th HDD is just sitting there on top of things, it is stuck to the top with a couple strips of ⅛” double sided sticky foam, which seems to isolate the vibration quite well for now.
Hopefully I can get my htpc built up soon, and move all those mechanical drives into there.
My newest build...it's still a bit of a work in progress. I'm in the process of putting together pieces of acrylic for water channels that will go in the top of the case, and I've used the "step up" program on the 970 in the pictures to move up to a 980ti, and have another on order for SLI. When the acrylic is placed in the top of the case, the soft tubing you see in the pictures will be replaced by acrylic tubing that will go straight up / down into / from the acrylic.
Doing the initial leak testing with distilled water
The reservoirs and fill ports. I have flat black bitspower 45s on the way to replace the black chrome fittings that I had laying around, in the interim.
This was the toughest bend in this loop. The back side of the reservoir mount.
The bends for the bottom of the reservoirs to tie into the D5 mod top.
Another angle from the picture above. The hard line to the left comes from the bulkhead adapter from the radiator in the bottom case, to the top of the reservoirs.
The EK Supremacy X99 EVO cpu block.
I really like the looks of this block, but just wasn't impressed enough with the GPU to keep it. The 2x 980tis I have on the way should fare much better.
The reservoirs and pumps from the back side..and the ugly soft tube that goes down to the bulkhead adapter that feeds through to the rad.
The Bitspower dual D5 mod top. Love these tops.
A shot of the front of the case....the front cover wouldn't fit on with both of the 230mm fans in the top, so I had to move one of them to the lower case....wasn't happy about that, but, I'll figure something else out down the road. I may just make a new front cover out of acrylic for the whole thing. Not sure yet.
The best part of the loop. It's performance. Love it. This is ambient room temp.
And loop temps with the sensor before the radiator. This after a 4 hour run on OCCT with the 5820k at 4.5ghz @ 1.315v. The MO RA3 420 is a beast, with those 230mm fans.
More pics in a few weeks when I get the 980tis in, tested, blocked and everything finalized with the acrylic water channels.
my build
new to the site but not to computers finally got around to updating some pictures and figured it was time to show off the beast, running 4930k at a daily 4.4ghz :attn: 11796292_10205089223339004_4624715596112623606_n.jpg 11800046_10205089224379030_6068815134923602611_n.jpg 11811388_10205089223779015_7052803394589903915_n.jpg 11825057_10205089224539034_877696105805002585_n.jpg 11828640_10205089224699038_5534393591314297740_n.jpg
You guys and your loop bends are making me jealous! lol I dont have the patience for it. I might just hire ya. lol But anyway, sick system Cert and Mclovin!
