So here's the lowdown: I'd like to have a bunch of LEDs in my room that are controlled by the music I'm listening to. I'd like to do this on as much of a budget as possible. I'm very experienced technically and can utilize solutions that involve programming or circuit modification.
I've found a bunch of these rgb led strips that can be controlled by ir or rf remote ( http://cgi.ebay.com/IR-Remote-Contr...ultDomain_0&hash=item4aa3d71dc2#ht_4879wt_911 ) but I want something more automated. It would be GREAT if I could modify some of the circuitry in these boxes to receive commands from my computer. Anyways here's what I've thought of so far:
- Using a microcontroller. There are so many different kinds however, I'm not sure which would be best. The only relevant tutorials I found call for microcontrollers over $100.
- Using my PSP. I think this would work great. I have a few extra PSPs and they're all modded to run homemade code.
- Using an iTouch. I don't think this has as much potential as the PSP. Impossible to take apart, much fewer output options, but still a possibility.
- Building a SUPER barebone computer (motherboard + cpu + ram I can find for under $70). I have a few old PCs lying around, but I wouldn't want to use those because they don't support booting from USB and I'd rather not have a noisy CD or hard drive as part of my setup.
So those are the brains of the setup. Here of course are my ideas for actually interfacing with the lights:
- Direct connection with serial or parallel. I obviously don't know much about doing this.
- Using IR commands. There are IR emitters for cents on eBay that plug into an audio jack. There are rgb light controllers that interface with IR. What if I were to cut out the middleman (quite literally) and wire audio outs directly to IR ins on the $7 light controllers. It seems like this would work optimally with the PSP or motherboard. The only problem is I don't know how exactly or if that would work. It would also be useful if I know other ways to send signals like that (other than from audio jacks) such as from USB or parallel ports, then I can control more light sets at once!
So let me know if anyone has done anything along these lines or has advice or can point me to a nice tutorial! I'd really like to use as much of what I already have so that I have more $$$ to spend on lights. This project isn't worth much if I only have a couple meter long led strips for the whole room! Even if this is the wrong forum/community to go looking in, let me know if somewhere else would be better!
