- Jan 18, 2010
- Calgary, Alberta, CANADA!
I'm planning on setting up a loop using a canister filter for fish tanks. It will pump water out of the tank through the cpu block ( it will be filtered first) then back into the fish tank. It's just an idea for now so any advice or problems you see would be a huge help.
