- Feb 3, 2005
I build a PC for a friend a couple of years ago using an Asus Z7S-WS motherboard. We installed 4 1TB drives and I created to RAID's using the Intel Matrix raid. A 500GB RAID 0 over the 4 drives for the OS and the rest as a RAID 5 for data.
Last week one of the drives failed so we got a replacement and put it in. I went into the RAID utility and we set the RAID 5 to re-build when the OS loads. I then deleted the RAID 0 as I wanted to replace it with a RAID 5 for the OS. However when I go to create a new RAID volume it wont let me select which disks or set the capacity. It will let me select the option of Create Volume but the volume size is 0GB.
Has anyone any ideas of what I can do to get this to work?
