Results 1 to 9 of 9
  1. #1
    Registered benny d.'s Avatar
    Join Date
    Oct 2010
    USA
    2x Molex 4-pin connectors for CrossFire on R3E advice...?
    Hello people,
    Aight, consulting the manual on the Rampage III Extreme it says that for those using multiple graphics cards the two Molex 4-pin power connectors should be utilized, anyone have any experience with this? Cable lengths back to my PSU are making this a pain so i'm working on extensions but more insight would be appreciated...
    out,
    b
    Intel i7 980x
    Asus ROG Rampage III Extreme
    Asus ROG Matrix 5870 Platinum x2 in CrossFire
    Corsair Dominator 1600MHz CAS7 6x2GB
    Corsair Hydro Series H70
    Crucial C300 128GB x3
    LG BluRay/DVD+RW
    Enermax Galaxy Evo 1250W
    Thermaltake Level 10
    Sony XBR 52" 1080p
  2. #2
    Join Date
    Apr 2010
    Quote Originally Posted by benny d. View Post
    Hello people,
    out,
    b
    It's to prevent to much power draw through your pcie slots. Check this out!
    http://www.overclock.net/nvidia/7709...-gtx-480s.html
    Hodgy
    CASE,Corsair Obsidian 800D
    Windows 7 Ultimate 64bit
    M/B,Asus Rampage III Extreme, EK-FB Acetal+Nickel
    CPU,Intel Core i7 980x, WC Corsair H50
    RAM, Corsair CMG6GX3M3A2000C7
    GPU, Asus GTX 480, WC EK-FC480 Acetal+Nickel, EVGA GTX 260 for Physx
    HD,WD VelociRaptro 150gb Raid0, WD Caviar Blue 1tb
    PSU,Corsiar 1000HX
  3. #3
    Join Date
    Oct 2010
    USA
    hellfire! nice catch brother, i'm playing it double-safe and not only using crossfire instead of sli but i'm gonna light both those connectors up as well... well played Asus, well played...
    Intel i7 980x
    LG BluRay/DVD+RW
    Sony XBR 52" 1080p
  4. #4
    Senior Member
    Bobnova's Avatar
    Join Date
    May 2009
    Author Profile Benching Profile Folding Profile Heatware Profile Rosetta Profile
    I think they're probably wired in parallel, so plugging into either one would do the trick.
    I doubt you need to if you aren't OCing the GPUs through the roof.
    That said, it certainly isn't going to hurt performance to plug in to one of them. I'd plug one in.
    "Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe." -- Einstein (maybe)
    Thinking about an Asus motherboard? Think again.
    How to check your PSU with a multimeter.
    17bXw5t51rEBXGavJFMJsC8g7HQgThUGc7
  5. #5
    I wouldn't plug there personally. Just get sleeved it will look much nice and tidy.
  6. #6
    Join Date
    Oct 2010
    USA
    Quote Originally Posted by Bobnova View Post
    Well, I am planning on flexing this entire system pretty hard for gaming so if what you say is true, at least one of 'em is getting used if not both. I'll check the manual again but I wonder how I could find out for sure if both of these are in parallel...?
    Intel i7 980x
    LG BluRay/DVD+RW
    Sony XBR 52" 1080p
  7. #7
    Senior Member
    Bobnova's Avatar
    Join Date
    May 2009
    You could take a multimeter to it and check the resistance between the 12v pins on the two connectors. Other then that, i don't think there is a way to know for sure.
  8. #8
    Join Date
    Oct 2010
    USA
    Yes sir, any idea what i'd see if they're perhaps in series, inf? Just starting to figure out how these things are wired...
    Intel i7 980x
    LG BluRay/DVD+RW
    Sony XBR 52" 1080p
  9. #9
    Join Date
    Oct 2010
    USA
    Huh, i'm showing no resistance between the +12V leads on both connectors, funny thing is is that i'm not showing any resistance between the +5V one one and the +12V on the other (and vice versa) either...?
    Intel i7 980x
    LG BluRay/DVD+RW
    Sony XBR 52" 1080p
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
